University VWF won't work
Hi @engtjm
You are running timing simulation in your vwf. "Run Functional Simulation" works fine.
Use timing analysis tool in the Quartus tool instead.
Richard Tan
Hi Richard,
I have tried to run the functional simulation in the University Program VWF, and I get the same error. Please see below.
With best regards, Tim
Determining the location of the ModelSim executable...
Using: C:/intelFPGA_lite/21.1/questa_fse/win64
To specify a ModelSim executable directory, select: Tools -> Options -> EDA Tool Options
Note: if both Questa Intel FPGA Edition and ModelSim executables are available, Questa Intel FPGA Edition will be used.
**** Generating the ModelSim Testbench ****
quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off decoder2 -c decoder2 --vector_source="C:/Users/engtj/Quartus/decoder2/Waveform.vwf" --testbench_file="C:/Users/engtj/Quartus/decoder2/simulation/qsim/Waveform.vwf.vt"
Info: *******************************************************************
Info: Running Quartus Prime EDA Netlist Writer
Info: Version 21.1.1 Build 850 06/23/2022 SJ Lite Edition
Info: Copyright (C) 2022 Intel Corporation. All rights reserved.
Info: Your use of Intel Corporation's design tools, logic functions
Info: and other software and tools, and any partner logic
Info: functions, and any output files from any of the foregoing
Info: (including device programming or simulation files), and any
Info: associated documentation or information are expressly subject
Info: to the terms and conditions of the Intel Program License
Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details, at
Info: https://fpgasoftware.intel.com/eula.
Info: Processing started: Fri Jan 27 16:38:15 2023
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=off decoder2 -c decoder2 --vector_source=C:/Users/engtj/Quartus/decoder2/Waveform.vwf --testbench_file=C:/Users/engtj/Quartus/decoder2/simulation/qsim/Waveform.vwf.vt
Warning (18236): Number of processors has not been specified which may cause overloading on shared machines. Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
Completed successfully.
**** Generating the functional simulation netlist ****
quartus_eda --write_settings_files=off --simulation --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory="C:/Users/engtj/Quartus/decoder2/simulation/qsim/" decoder2 -c decoder2
Info: Processing started: Fri Jan 27 16:38:17 2023
Info: Command: quartus_eda --write_settings_files=off --simulation=on --functional=on --flatten_buses=off --tool=modelsim_oem --format=verilog --output_directory=C:/Users/engtj/Quartus/decoder2/simulation/qsim/ decoder2 -c decoder2
Info (204019): Generated file decoder2.vo in folder "C:/Users/engtj/Quartus/decoder2/simulation/qsim//" for EDA simulation tool
Info: Quartus Prime EDA Netlist Writer was successful. 0 errors, 1 warning
Info: Peak virtual memory: 4649 megabytes
Info: Processing ended: Fri Jan 27 16:38:17 2023
Info: Elapsed time: 00:00:00
Info: Total CPU time (on all processors): 00:00:01
**** Generating the ModelSim .do script ****
C:/Users/engtj/Quartus/decoder2/simulation/qsim/decoder2.do generated.
**** Running the ModelSim simulation ****
C:/intelFPGA_lite/21.1/questa_fse/win64/vsim -c -do decoder2.do
Error.
