University Program VWF simulation
- 10 months ago
In the Simulation Waveform Editor, Go to Simulation -> Simulation Settings.
Next, delete -novopt and Save.
The error should resolved when Run Functional SimulationRegards,
Richard Tan
Thanks it works fine but how to make this change permanently ? A config file to change ?
Eric
Unfortunately, there isn’t a way to retain modified simulation settings automatically.
As a workaround, you can save the .vwf file with your updated simulation settings and include it in your project manually.
However, I generally recommend using the Nativelink Simulation Flow, which allows you to view the simulation directly in the Questa simulator tool.
https://www.intel.com/content/www/us/en/docs/programmable/683080/23-1/using-nativelink-simulation.html
Richard Tan
- ETang210 months ago
Thank you for the workaround i will give it a try replacing -novop by -voptargs="+acc"
Nevertheless it's a bug and i will open a bug ticket about this. There are still a lot of script using this deprecated option.
I'm using the Nativelink Simulation Flow, with advanced or intermediate students because they know description language and testbench but not with first years students discovering basic logic gate circuits.
Eric
