9 years agoUniversity license for OpenCL?
I'm trying to follow the introduction to OpenCL videos (https://www.youtube.com/watch?v=4pukzi14mly) but I'm currently stuck when trying to compile OpenCL for my board:
aoc device/vector_add.cl -o bin/vector_add.aocx --report
aoc: Selected default target board s5_ref
/home/renagen/opt/intelFPGA/16.1/opencl_example_vector_soc/vector_add/device/vector_add.cl:23:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
__kernel void vector_add(__global const float *x,
/home/renagen/opt/intelFPGA/16.1/opencl_example_vector_soc/vector_add/device/vector_add.cl:24:48: warning: declaring kernel argument with no 'restrict' may lead to low kernel performance
__global const float *y,
2 warnings generated.
Could not acquire a valid license for the Intel(R) FPGA SDK for OpenCL(TM).
Error: Verilog generator FAILED.
Refer to vector_add/vector_add.log for details. The LM_LICENSE_FILE is pointing to my license file which contains: # Altera SDK for OpenCL (University), 1 Seat(s)# - Maintenance Expiration of 2018.01 Have you ever experienced such kind of error? Does anyone know if the University license is compatible for such use? Thanks.4 Replies
Yes, but the only times I have seen this issue is when either my environment setting was wrong, the license itself was wrong, or if I had placed the file in the wrong location...
Thanks for the feedback. A simple
tells me that it's actually correctly set. It must come from the license itself. Has anyone here already tried with a University license ? :)cat $LM_LICENSE_FILE - Altera_Forum
Are you running on Linux? The network interface needs to be named eth0. If you have a reasonably new Linux distro it is probably named something like enp0 (check by e.g. typing "ip link show" in a terminal), but you can create a virtual network interface with the name eth0 with the MAC (also called NIC) adress that is specified in your license file:
sudo ip tuntap add dev eth0 mode tap sudo ip link set dev eth0 address <your mac address> - Altera_Forum
Great, it works now!
Yes, I am running archlinux (I should have read the dedicated wiki page there, it was also explained). Thanks a lot!
