Uninstall 13.1.0.162 quartus2
Dropping a note to ask if my last reply was helpful to you.
Do you need any further assistance from my side?
Richard Tan
Hi!!
I am currently having the same issue. I tried deleting the folder or uninstalling from Control Panel without success. What else could I do?
Any help would be appreciated.
- RichardT_altera1 year ago
Have you try to manually delete the remaining files or folders, in C:\intelFPGA or your custom installation directory?
Try to reinstall the same Quartus version (make sure to put it in the same directory as it was previously), then attempt to uninstall it again.
Richard Tan- Betty11 year ago
Unfortunately, I don't have the spare memory to install it again. Specially if I need to install it in the same directory. It was quite a challenge to release 1 GB, I can't do the whole program again. Is there another alternative?
Which Quartus version are you using? Are you using Window OS?
Richard Tan
