tpwls
2 years agounconstarained path error
Hello! I was working on a lab code at school and encountered an error in the timequest timing analyze part. At first, a negative slack error and an unconstrained path error occurred together, but I...
TingJiangT_Intel
Contributor
2 years agoHi there, please check if there has some conflict constraint on this first, or if the overwriting is a right sdc you can ignore the warning.
As the previous reply, you'd better combine this two sdc file to ensure there is no conflict.
