tpwls
2 years agounconstarained path error
Hello! I was working on a lab code at school and encountered an error in the timequest timing analyze part. At first, a negative slack error and an unconstrained path error occurred together, but I...
tpwls
2 years agoI solved the problem by creating a manual.out.sdc file with input/output delay set to 0 using TimeQuest Timing Analyze.
However, 332043 Overwriting existing clock: error has been added. How should this be resolved?
Thank you.
