Altera_ForumHonored Contributor13 years agounconnect port warning. when a instance port is not connected, Quartus report a connectivty issue. how to avoid this.
Altera_ForumHonored Contributor13 years agothank you. but i like use Verilog. Do you know how write Verilog code like this?
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
