RHenr
2 years agoUnable to use Avalon-MM master verification BFM in Questa sim
I have a bug similar to the one reported here :
https://community.intel.com/t5/Intel-Quartus-Prime-Software/Avalon-Verification-IP-example-avlmm-1x1-vhdl-not-working-in/m-p/1516388
I tried to follow the given solution, but it makes Questa sim crash. Moreover, it seems the -novopt option is deprecated.
If I remove the "-suppress 12110" option, Questa sim does not crash but reports this error, thus simulation is also not possible.
# ** Error (suppressible): (vsim-12110) All optimizations are disabled because the -novopt option is in effect. This will cause your simulation to run very slowly. If you are using this switch to preserve visibility for Debug or PLI features, please see the User's Manual section on Preserving Object Visibility with vopt. -novopt option is now deprecated and will be removed in future releases.
