11 years ago
Unable to update property "Weak Pull-Up Resistor"
I am trying to set assign an internal pull up resistor to an input on the Cyclone IV E: EP4CE15F23C8 on Quartus II 11.0. I have tried using both the assignment editor and the pin planner to accomplish this, but after compilation this critical error always appears: critical warning: unable to update property "weak pull-up resistor" of node "idestuffed". The pin I am trying to assign is pin L6, I have tried some other pins and most also experience the same problem, but pin K1 does not. I can't seem to find the difference between the two pins. Is there some way to remedy this or another way to pull up the signal.
Thanks in advance.
    Are you using (knowingly or otherwise) the bus-hold feature? From the "I/O Features in Cyclone IV Devices" (page 6-4):
    --- Quote Start ---
    If you enable the bus-hold feature, the device cannot use the programmable pull-up option.
    --- Quote End ---
    Alex
    Thanks for the reply Alex. I have checked to make sure the bus-hold feature is off. Another thing I have noticed is that I do not receive the critical warning in Quartus 12.0 or Quartus 13.0. I would rather use Quartus 11.0, but if it's not possible I will have to port my project.
