15 years agowhichever core you are trying to simulated in NativeLink has to be set as the top level entity of your Quartus project, then you have to run (at least) Analysis and Elaboration for an RTL simulation
to switch quickly between top level entities, you can use Quartus II Revisions, which will create separate qsf files for each revision where you could set different top entities in each
