17 years agoThis is the summary of my IP's compilation report:
--- Quote Start --- Total logic elements 1,859 / 18,752 ( 10 % ) -- Combinational with no register 777 -- Register only 224 -- Combinational with a register 858 Logic element usage by number of LUT inputs -- 4 input functions 492 -- 3 input functions 635 -- <=2 input functions 508 -- Register only 224 Logic elements by mode -- normal mode 1138 -- arithmetic mode 497 Total registers* 1,082 / 19,649 ( 6 % ) -- Dedicated logic registers 1,082 / 18,752 ( 6 % ) -- I/O registers 0 / 897 ( 0 % ) Total LABs: partially or completely used 133 / 1,172 ( 11 % ) User inserted logic elements 0 Virtual pins 0 I/O pins 45 / 315 ( 14 % ) -- Clock pins 1 / 8 ( 13 % ) Global signals 2 M4Ks 2 / 52 ( 4 % ) Total memory bits 4,800 / 239,616 ( 2 % ) Total RAM block bits 9,216 / 239,616 ( 4 % ) Embedded Multiplier 9-bit elements 0 / 52 ( 0 % ) PLLs 0 / 4 ( 0 % ) Global clocks 2 / 16 ( 13 % ) Average interconnect usage 2% Peak interconnect usage 4% Maximum fan-out node clk~clkctrl Maximum fan-out 1039 Highest non-global fan-out signal quad16:q16|nlfsr10:nlfsr_10|wradd[4]~731 Highest non-global fan-out 520 Total fan-out 8026 Average fan-out 2.72 --- Quote End ---
