17 years agoseems to me that each of the 32 dprams should only use 1 M4K.
http://www.altera.com/literature/hb/cyc2/cyc2_cii5v1_03.pdf shows that the M4K can be configured to 4K x 1. It also show that the EP2C20 has 52 M4Ks. This would make me assume that the rest of the system is using the other 233 M4Ks(error message says cannot fit 265 RAM CELLS... 265 - 32(from the IP) = 233). What is the size of the on chip memory? Are there multiple instances of your custom IP?
