11 years agounable to open the device acl0 when using aocl program command
hi all, i am trying to set up my de5-net board. i firstly flash to the initial configuration by typing "aocl flash acl0 hello_world.aocx ", which executed succesfully. then i type "aocl program ac...
driverdan
6 years agoHey David, Dong, Chris
I am using version 18.0 and have flashed and shutdown the machine several times, for longer and longer time periods and still get MMD ERROR: [acl0] failed to open the device.
C:\intelFPGA\18.0\hld\board\terasic\de5net\tests\hello_world\bin>aocl program acl0 hello_world.aocx
aocl program: Running program from c:/intelFPGA/18.0/hld/board/terasic/de5net/windows64/libexec
Unable to open the device acl0.
aocl program: Program failed.
the physical factory image switch is set to 0 and so is the pcie jtag image. so therefore that means the pcie jtag image should be on. and also the mini usb is still plugged in.
