11 years agounable to open the device acl0 when using aocl program command
hi all, i am trying to set up my de5-net board. i firstly flash to the initial configuration by typing "aocl flash acl0 hello_world.aocx ", which executed succesfully. then i type "aocl program ac...
10 years agoHi Dong,
Ryan is correct: you do need to perform a power-cycle (power needs to go off once and then on again) for the FPGA to actually load the image. A simple reboot will not do it. David
