11 years agounable to open the device acl0 when using aocl program command
hi all, i am trying to set up my de5-net board. i firstly flash to the initial configuration by typing "aocl flash acl0 hello_world.aocx ", which executed succesfully. then i type "aocl program ac...
10 years agoHi David,
I still have the "Unable to open the device acl0" problem even after I have restarted the machine. The flash is programed by using the aocl flash command. I also printed the kernel message and it shows that : [ 2708.215450] aclpci_init (676): [ 2708.215453] ---------------------------- [ 2708.215456] aclpci_init (677): [ 2708.215458] Driver version: 14.0.32 [ 2708.215471] aclpci_init (698): [ 2708.215472] pci_register_driver [ 2708.215526] aclpci_init (704): [ 2708.215527] success I suppose that the driver is running OK. Then I am not sure what caused the failed of the programming process. Please help me ~~ I am using the DE5-NET board too. Thansk Dong
