BStui2
6 years agoUnable to install Arria 10 devices under Quartus Prime 19 on Ubuntu 18.04 LTS, --unzip_tool option does not help.
Hi, I am tring to install Quartus prime on Ubuntu 18.04 LTS. This should work because it is supported. Quartus itself installs ok. However I am unable to install the Arria 10 devices. The installer s...
BStui2
6 years agoNo update, i am working around the problem by running Quartus 19.4.0 build 64 on a Windows 7 machine, as i can install both the Quartus software and devices. Only modelsim fails to install, I work around that by using Vivado for simulation.
Cheers!
