BStui2
6 years agoUnable to install Arria 10 devices under Quartus Prime 19 on Ubuntu 18.04 LTS, --unzip_tool option does not help.
Hi, I am tring to install Quartus prime on Ubuntu 18.04 LTS. This should work because it is supported. Quartus itself installs ok. However I am unable to install the Arria 10 devices. The installer s...
BStui2
6 years agoUnfortunately, as I am trying to reproduce to answer your request by attempting to install Quartus Prime 19.04 on Windows 10, it now completely hangs after approximately 15%, without any error message. Perhaps to much junk left from previous attempts?
I was able to successfully install the 18.0 version though. However, currently I am working on Windows 7 with the 19.04 version. But I was unable to install Modelsim on that one. Fortunately it seems Signaltap is all I need at the moment.
The pop-up you refer to mention suggests to use the --unizp_tool option and specify with unzip tool, including path, being 7z or unzip tools which are supported.
Cheers!
