BStui2
6 years agoUnable to install Arria 10 devices under Quartus Prime 19 on Ubuntu 18.04 LTS, --unzip_tool option does not help.
Hi, I am tring to install Quartus prime on Ubuntu 18.04 LTS. This should work because it is supported. Quartus itself installs ok. However I am unable to install the Arria 10 devices. The installer s...
BStui2
6 years agoI just tried to install the arria 10 devices from Quartus directly (tools-->install devices), i run into the same problem.
After a looong while there is a pop-up that says: try using your own unzip tool.
By the way, apparently Quartus calls the installer to handle device installation, that is the QDZ file.
