BStui2
6 years agoUnable to install Arria 10 devices under Quartus Prime 19 on Ubuntu 18.04 LTS, --unzip_tool option does not help.
Hi, I am tring to install Quartus prime on Ubuntu 18.04 LTS. This should work because it is supported. Quartus itself installs ok. However I am unable to install the Arria 10 devices. The installer s...
KennyT_altera
6 years agowhat is the file format that you are using. If you already see the qdz file, you do not need to unzip it. Just used it by quartus -> tools -> install device
