Unable to get LED blink on the FPGA board Cyclone V 5CGXFC5C6F27C7N
Are you using an Altera board or your custom board?
For the statement: Once the code was programmed, they got 2.3V on the multimeter for all the output JTAG pins.
May I know what you meant by this? There is only one JTAG output pin which is - TDO. Do you power the pin with a 2.5V?
Can you help to measure the clock with the oscilloscope and verify if it is toggling?
As a sanity check, it is recommended for you to run RTL simulation first.
Aqid
- FPGA_user22 years ago
Hello AqidAyman_Intel,
Sir, I am using a custom board.
For the statement: Can you help to measure the clock with the oscilloscope and verify if it is toggling?
Yes, I have checked the clock output in the oscilloscope; it's sinusoidal with a 50 MHz frequency. The IC number is U7. The oscilloscope used was 100MHz, 2GSa/s.
The RTL simulation is also run.
RTL simulation
Could we have a Teams meeting to discuss further about this issue?
Thank You
