Unable to generate legacy license for Quartus II V6.1 on virtual machine
- 3 years ago
Hello all,
Apologies for the delay in responding. Anyway, I figured out how to generate a valid license.
"Sign up for Evaluation or Free Licenses" at the top of the webpage needs to be selected. From there, select "Inter Quartus II Software SW-QUARTUS-WE-FIX"
From here, select "+New computer" under "Create a New Computer"
Under "Computer Type," select "NIC ID." For the Primary Computer ID and Companion Computer ID 2 fields, put the physical addresses of the VMware network adapters. These should be listed in the Local System info under the License Setup menu in Quartus.
This will generate a valid license file.
Thank you to all who assisted with this issue.
Thanks for your update, hope all is well. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
