Unable to generate legacy license for Quartus II V6.1 on virtual machine
- 3 years ago
Hello all,
Apologies for the delay in responding. Anyway, I figured out how to generate a valid license.
"Sign up for Evaluation or Free Licenses" at the top of the webpage needs to be selected. From there, select "Inter Quartus II Software SW-QUARTUS-WE-FIX"
From here, select "+New computer" under "Create a New Computer"
Under "Computer Type," select "NIC ID." For the Primary Computer ID and Companion Computer ID 2 fields, put the physical addresses of the VMware network adapters. These should be listed in the Local System info under the License Setup menu in Quartus.
This will generate a valid license file.
Thank you to all who assisted with this issue.
Hello
Welcome to INTEL forum. For legacy software you can try get a license using the Legacy License Generator. https://www.intel.com/content/www/us/en/programmable/support/support-resources/download/licensing/lic-choose.html
If error, could you get me the screenshot of error message. TQ
