Unable to generate legacy license for Quartus II V6.1 on virtual machine
- 3 years ago
Hello all,
Apologies for the delay in responding. Anyway, I figured out how to generate a valid license.
"Sign up for Evaluation or Free Licenses" at the top of the webpage needs to be selected. From there, select "Inter Quartus II Software SW-QUARTUS-WE-FIX"
From here, select "+New computer" under "Create a New Computer"
Under "Computer Type," select "NIC ID." For the Primary Computer ID and Companion Computer ID 2 fields, put the physical addresses of the VMware network adapters. These should be listed in the Local System info under the License Setup menu in Quartus.
This will generate a valid license file.
Thank you to all who assisted with this issue.
Maybe there are NICs for some kind of virtual switch inside VMware? My setup is a bit different: Quartus directly on Win11 on a Dell PC, but I'm also running a VM under HyperV and "ipconfig /all" reports three NICs. You can check the associated manufacturer from the MAC address at a site like https://dnschecker.org/mac-lookup.php In my case two of the NICs decode to Microsoft, and these are the virtual ones associated with HyperV. But the third NIC MAC decodes to Dell and is the real hardware NIC. I guess the license site may require a NIC associated with real hardware.
