14 years agoUnable to fit a partition even if OUTPUTS are declared Virtual Pins
Since I couldn't find any relevant answer in previous posts or tutorials, here's my 1st post, with a "tough" question.
I have a medium-size Quartus II v.9.0 project for Cyclone III EP3C5E144, which I want to partition, with 1 partition being a subdesign and the 2nd partition being everything else. I followed the very clear step-by-step tutorial and everything went smooth, until I hit a nasty unexpected error. My partitioned subdesign has an output to the parent level, which is a large parallel register (268 outputs). --------- excerpt from .TDF --------- frame_drop[267..0] : OUTPUT; ------------------------------------- When generating the partition, outputs frame_drop[267..0] have been declared "Virtual Pin", and they are listed as "Virtual Pin", "On" in the Assignment Editor. But when I Start a Compilation of the partition, it successfully completes Analysis and Synthesis, but fails to Fit, with error message: "Can't place 208 pins with 2.5 V I/O standard because Fitter has only 88 such free pins available." Now I wonder: why is Quartus trying to fit these 268 partition outputs to *physical* output pins, since it knows they are *Virtual* pins? I am running a licensed Quartus II v.9.0 SP2 (License Type = Full Version in License Setup). Thank you for your kind help, Mauro Cerisola
