Prerana1
2 years agoUnable to detect the device
The problems we are facing are : I am using ALTERA MAX10 FPGA Development board and i m using Quartus prime lite 23.1 lite edition. So when i went to tools and in that i selected programmer , So t...
sstrell
2 years agoPower cycle the board and check if you accidentally have any DIP switches set that may remove the device from the JTAG chain.
Since the Programmer is seeing the USB Blaster, the device should be there.
- Prerana12 years ago
Hi
I did check for these but the device is still not getting detected(can you tell me whether to keep the DIP switches high or low).
I tried all the possible ways looking at user manual but nothing is working out.
I have one more board which is DECA MAX 10 ALTERA FPGA EVALUATION BOARD , for this board also same issue is happening ,the device is not getting detected in Quartus Prime.
Can you tell me what to do about this issue.
Thankyou
