10 years agoUltrasonic sensor hc-sr04 vhdl code
Hi guys, i found ultrasonic sensor HC-SR04 code implemented in Altera DE2-115 board here https://github.com/rutgers-fpga-projects/ngc-sonar
My project aims to use the Altera DE2 board with ultrasonic sensor HC-SR04 and I modified the declaration of GPIO expansion header to be suited to Altera DE2. Here's the modified codeLIBRARY ieee;USE ieee.std_logic_1164.ALL;
use ieee.numeric_std.ALL;
ENTITY final IS
PORT(
CLOCK_50 : IN STD_LOGIC; -- 50MHz
SW : IN STD_LOGIC_VECTOR(17 DOWNTO 0);
KEY : IN STD_LOGIC_VECTOR(3 DOWNTO 0);
LEDG : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR(17 DOWNTO 0);
GPIO_0 : INOUT STD_LOGIC_VECTOR(40 DOWNTO 1);
-- LCD controller stuff
LCD_RS, LCD_EN : OUT STD_LOGIC;
LCD_RW : OUT STD_LOGIC;
LCD_ON : OUT STD_LOGIC;
LCD_DATA : INOUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END final;
ARCHITECTURE arch OF final IS
-- convert our 2 digits of hex to 3 digits of BCD
FUNCTION to_bcd ( bin : STD_LOGIC_VECTOR(7 DOWNTO 0) ) RETURN STD_LOGIC_VECTOR IS
VARIABLE i : integer:=0;
VARIABLE bcd : STD_LOGIC_VECTOR(11 DOWNTO 0) := (OTHERS => '0');
VARIABLE bint : STD_LOGIC_VECTOR(7 DOWNTO 0) := bin;
BEGIN
FOR i IN 0 TO 7 LOOP -- repeating 8 times.
bcd(11 DOWNTO 1) := bcd(10 DOWNTO 0); --shifting the bits.
bcd(0) := bint(7);
bint(7 DOWNTO 1) := bint(6 DOWNTO 0);
bint(0) :='0';
IF(i < 7 and bcd(3 DOWNTO 0) > "0100") THEN --add 3 if BCD digit is greater than 4.
bcd(3 DOWNTO 0) := STD_LOGIC_VECTOR(UNSIGNED(bcd(3 DOWNTO 0)) + 3);
END IF;
IF(i < 7 and bcd(7 DOWNTO 4) > "0100") THEN --add 3 if BCD digit is greater than 4.
bcd(7 DOWNTO 4) := STD_LOGIC_VECTOR(UNSIGNED(bcd(7 DOWNTO 4)) + 3);
END IF;
IF(i < 7 and bcd(11 DOWNTO 8) > "0100") THEN --add 3 if BCD digit is greater than 4.
bcd(11 DOWNTO 8) := STD_LOGIC_VECTOR(UNSIGNED(bcd(11 DOWNTO 8)) + 3);
END IF;
END LOOP;
RETURN bcd;
END to_bcd;
-- LCD display controller
COMPONENT LCD_Display IS
PORT(
KEY : IN STD_LOGIC_VECTOR(0 downto 0);
Hex_Display_Data : IN STD_LOGIC_VECTOR(11 DOWNTO 0); --STD_LOGIC_VECTOR((Num_Hex_Digits*4)-1 DOWNTO 0);
LCD_DATA : INOUT STD_LOGIC_VECTOR(7 DOWNTO 0);
inch_cent_switch : IN STD_LOGIC;
lds : IN STD_LOGIC_VECTOR(15 DOWNTO 0));
END COMPONENT;
SIGNAL graphical_length_display : STD_LOGIC_VECTOR(15 DOWNTO 0);
SIGNAL reset: STD_LOGIC;
SIGNAL trigger : INTEGER:= 500; -- 10us
SIGNAL counter : INTEGER;
SIGNAL MAX_CYCLES : INTEGER; -- number of cycles per sample cycle
SIGNAL count_dist: INTEGER; -- number of in/cm
SIGNAL hex: STD_LOGIC_VECTOR (7 DOWNTO 0);
SIGNAL decimal : STD_LOGIC_VECTOR(11 DOWNTO 0);
SIGNAL inch_conversion_factor : INTEGER := 7231;
SIGNAL cent_conversion_factor : INTEGER := 2847;
SIGNAL inch_cent_switch : STD_LOGIC;
SIGNAL sample_speed_switch : STD_LOGIC;
SIGNAL max_inches : INTEGER := 120;
SIGNAL max_centimeters : INTEGER := 300;
SIGNAL startcount, elapsed : INTEGER;
BEGIN
reset <= NOT KEY(1);
inch_cent_switch <= SW(0); -- 0 = centimeter, 1 = inch
sample_speed_switch <= SW(1);
-- set sample rate
WITH sample_speed_switch SELECT
MAX_CYCLES <= 50000000 WHEN '0', -- 1 sample per second
12500000 WHEN '1'; -- 4 samples per second
-- sampling cycle loop
-- increments counter variable and resets when sampling cycle is over
PROCESS(RESET, CLOCK_50)
BEGIN
IF reset='1' THEN
counter<= 0;
ELSIF RISING_EDGE(CLOCK_50) THEN
counter <= counter +1;
IF(counter > MAX_CYCLES) THEN
counter <= 0;
END IF;
END IF;
END PROCESS;
-- trigger signal
PROCESS(counter)
BEGIN
IF(counter < trigger) THEN -- 0 to 10us
GPIO_0(3) <= '1'; -- trigger
ELSE
GPIO_0(3) <= '0';
END IF;
END PROCESS;
-- echo signal listener
PROCESS(GPIO_0(1))
BEGIN
IF(RISING_EDGE(GPIO_0(1))) THEN
startcount <= counter;
ELSIF(FALLING_EDGE(GPIO_0(1))) THEN
elapsed <= counter - startcount; -- gets length of echo pulse
IF(inch_cent_switch = '0') THEN
count_dist <= elapsed / cent_conversion_factor; -- convert length in clocks to length in centimeters
-- determine bar length for display
IF(count_dist > (max_centimeters * 15) / 16) THEN
graphical_length_display <= "1111111111111111";
ELSIF(count_dist > (max_centimeters * 14) / 16) THEN
graphical_length_display <= "1111111111111110";
ELSIF(count_dist > (max_centimeters * 13) / 16) THEN
graphical_length_display <= "1111111111111100";
ELSIF(count_dist > (max_centimeters * 12) / 16) THEN
graphical_length_display <= "1111111111111000";
ELSIF(count_dist > (max_centimeters * 11) / 16) THEN
graphical_length_display <= "1111111111110000";
ELSIF(count_dist > (max_centimeters * 10) / 16) THEN
graphical_length_display <= "1111111111100000";
ELSIF(count_dist > (max_centimeters * 9) / 16) THEN
graphical_length_display <= "1111111111000000";
ELSIF(count_dist > (max_centimeters * 8) / 16) THEN
graphical_length_display <= "1111111110000000";
ELSIF(count_dist > (max_centimeters * 7) / 16) THEN
graphical_length_display <= "1111111100000000";
ELSIF(count_dist > (max_centimeters * 6) / 16) THEN
graphical_length_display <= "1111111000000000";
ELSIF(count_dist > (max_centimeters * 5) / 16) THEN
graphical_length_display <= "1111110000000000";
ELSIF(count_dist > (max_centimeters * 4) / 16) THEN
graphical_length_display <= "1111100000000000";
ELSIF(count_dist > (max_centimeters * 3) / 16) THEN
graphical_length_display <= "1111000000000000";
ELSIF(count_dist > (max_centimeters * 2) / 16) THEN
graphical_length_display <= "1110000000000000";
ELSIF(count_dist > (max_centimeters * 1) / 16) THEN
graphical_length_display <= "1100000000000000";
ELSIF(count_dist > (max_centimeters * 0) / 16) THEN
graphical_length_display <= "1000000000000000";
END IF;
ELSIF(inch_cent_switch = '1') THEN
count_dist <= elapsed / inch_conversion_factor; -- convert length in clocks to length in inches
IF(count_dist > (max_inches * 15) / 16) THEN
ELSIF(count_dist > (max_inches * 14) / 16) THEN
ELSIF(count_dist > (max_inches * 13) / 16) THEN
ELSIF(count_dist > (max_inches * 12) / 16) THEN
ELSIF(count_dist > (max_inches * 11) / 16) THEN
ELSIF(count_dist > (max_inches * 10) / 16) THEN
ELSIF(count_dist > (max_inches * 9) / 16) THEN
ELSIF(count_dist > (max_inches * 8) / 16) THEN
ELSIF(count_dist > (max_inches * 7) / 16) THEN
ELSIF(count_dist > (max_inches * 6) / 16) THEN
ELSIF(count_dist > (max_inches * 5) / 16) THEN
ELSIF(count_dist > (max_inches * 4) / 16) THEN
ELSIF(count_dist > (max_inches * 3) / 16) THEN
ELSIF(count_dist > (max_inches * 2) / 16) THEN
ELSIF(count_dist > (max_inches * 1) / 16) THEN
ELSIF(count_dist > (max_inches * 0) / 16) THEN
END IF;
END IF;
END IF;
END PROCESS;
-- get hex out of integer
hex <= STD_LOGIC_VECTOR(TO_UNSIGNED(count_dist, 8));
-- get BCD out of hex
decimal <= to_bcd(hex);
-- instantiate LCD controller
lcd : LCD_Display PORT MAP(KEY(0 DOWNTO 0),CLOCK_50, decimal,LCD_RS, LCD_EN,LCD_RW ,LCD_ON,LCD_DATA, inch_cent_switch, graphical_length_display);
END arch; So far, this code didn't give error. When downloaded to the board, the LCD only show the unit of measurement not the value of measurement. How to solve it?No RepliesBe the first to reply
