Altera_ForumHonored Contributor12 years agoUart - with two altera board Hello, i would like to know if is possible use the RS232 between two different altera DE1 board. i've got a code that works with pc (i using a terminal like putty / realterm) but when i try to ...Show More
Altera_ForumHonored Contributor12 years agoOf course it's possible. I presume you are using a nullmodem cable (crossing Rx and Tx).
Recent DiscussionsConnection bit order between hierarchyHow to fix Error(23782): Failed to find an expected reportSolvedQuartus 22.1 and 23.1 Synthesis ErrorCould not link 'vsim_auto_compile.dll' error troubleshooting.Failed to run ip-setup-simulation:
