15 years ago
Type do not match for port
--- Quote Start ---
WARNING[1]: D:/Quartus/January_2011/Final 1/PhamNT.vhd(75): Types do not match for port x_in
WARNING[1]: D:/Quartus/January_2011/Final 1/PhamNT.vhd(75): A use of this default binding for this component instantiation will result in an elaboration error.
WARNING[1]: D:/Quartus/January_2011/Final 1/PhamNT.vhd(75): Types do not match for port u_in
WARNING[1]: D:/Quartus/January_2011/Final 1/PhamNT.vhd(75): Types do not match for port err
WARNING[1]: D:/Quartus/January_2011/Final 1/PhamNT.vhd(75): Types do not match for port yn
--- Quote End ---
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.std_logic_arith.ALL;
USE ieee.std_logic_unsigned.ALL;
entity PhamNT is
  port(x_in,kd,ki,kp  :in signed(15 downto 0):=(others => '0');
       clk            :in std_logic:='0';
       clk_op         :in std_logic:='0';
       yn             :out signed (15 downto 0):=(others => '0')
end PhamNT;
ARCHITECTURE structural OF PhamNT IS
  signal u,y         :signed(15 downto 0):=(others => '0');  --x(n-1),Y(n-1)
  signal err         :signed(15 downto 0):=(others => '0');
  signal go          :std_logic:='0';
  signal pl_go :std_logic:='0';
  signal	start 			: std_logic:='0';
  signal    mic_in 			: signed(15 downto 0):=(others => '0');
  signal    z_out          	: signed(15 downto 0):=(others => '0');
  signal    done           	: std_logic:='0';
  signal    u_in  	: signed(15 downto 0):=(others => '0');
  component simp_cpu IS
  PORT(start : in std_logic;
       mic_in,kd,ki,kp  :in signed(15 downto 0);
       z_out          :out signed(15 downto 0);
       done           :out std_logic;
       clk            :in std_logic );
  END component;
  component dtdk_plant is
  port(x_in  :in signed(15 downto 0);
       u_in  :in signed(15 downto 0);
       go :in std_logic;
       clk   :in std_logic;
       clk_op :in std_logic;
       err :out signed(15 downto 0);
       yn    :out signed(15 downto 0);
       pl_go :out std_logic);
  end component;
begin
U_Simp_CPU: simp_cpu port map (
							start	=> pl_go,
							mic_in	=> err,
							kd		=> kd,
							ki		=> ki,
							kp		=> kp,
							z_out	=> u,
							done	=> go,
							clk	=> clk_op
U_dtdk_plant: dtdk_plant port map(
					x_in	=>	x_in,
					u_in	=>	u,
					go		=>	go,
					clk		=>	clk,
					clk_op	=>	clk_op,
					err		=>	err,
					yn		=>	yn,
					pl_go	=>	pl_go
end structural ;
When I compile it's ok. But I simulate it error. I did not know this error. Could you help me? Thanks (I use Modelsim)
    --- Quote Start ---
    Component 'lop1_a' is not bound
    --- Quote End ---
    Usually, you forgot to compile the source containing the component definition.
    --- Quote Start ---
    A := RF(CONV_INTEGER(fld_a));
    If fld_a = 0, my result always is "X".
    --- Quote End ---
    What is RF()? A function or an array?
    RF is a register file.
    I used fld_a as an address to read the value of RF.
    TYPE reg_fileT IS ARRAY(0 TO 8) OF std_logic_vector(15 DOWNTO 0);
    SIGNAL RF                 :reg_fileT;
    Then the X most likely means, that a 'X' has been written to the register. You can visualize the register content in Modelsim, and you also can force the register manually to check, if the result changes.
    Oh. Thank you very much. I make a mistake with RF.
    by the way, Can you help me to initial for this RF.
    TYPE reg_fileT IS ARRAY(0 TO 8) OF SIGNED(15 DOWNTO 0):=(others=>'0');
    I can not initial by this way, it had an error.
    Yes, it must be 2-D.
    TYPE reg_fileT IS ARRAY(0 TO 8) OF SIGNED(15 DOWNTO 0):=(others=>(others=>'0'));
    I'm sorry. Could you check this for me? the quartus still show an error in this declaration.
    Error (10500): VHDL syntax error at data_subsys.vhd(21) near text ":=";  expecting ";"
    You cannot initialise a type, you have to initialise a constant/signal/variable.
    so do this instead:
    TYPE reg_fileT IS ARRAY(0 TO 8) OF SIGNED(15 DOWNTO 0);
    signal  RF : reg_fileT :=(others=>(others=>'0'));
    I have once more question:
    I program this code and I've already initial all value but the output zzero, ccy, sometime their value are "U", "1", "0". Their value are "1" and "0" it's Ok but the value is "U", I can not soft it. Could you help me?
    VARIABLE A,B,C           :std_logic_vector(15 DOWNTO 0):=(others => '0');
    VARIABLE alu_out         :std_logic_vector(15 DOWNTO 0):=(others => '0');
    VARIABLE zzero,nneg,ccy  :STD_LOGIC:='0';
    constant z :std_logic_vector(15 downto 0) := (others => '0');
    procedure alu (zzero,nneg,ccy  :out STD_LOGIC;
                   alu_out         :out std_logic_vector(15 DOWNTO 0);
                   a,b             :in std_logic_vector(15 DOWNTO 0):=(others => '0');
                   alu_op          :in UNSIGNED(2 DOWNTO 0):=(others =>'0')) is
    variable alu_out_reg :std_logic_vector(16 DOWNTO 0):=(others => '0');
    variable alu_out_or  :std_logic_vector(31 downto 0):=(others => '0');
    begin
      case alu_op  is
        when "000" =>     alu_out_reg := ("0" & a) + ("0" & b); ------add
                         alu_out := alu_out_reg(15 downto 0);
                         ccy := alu_out_reg(16);
                         if alu_out_reg(15 downto 0) = z then
    					 zzero := '1';
                         else zzero:= '0';
                         end if;
        when others =>  null;
      end case;
    end  alu;
    BEGIN
      A := RF(conv_integer(fld_a));
      B := RF(conv_integer(fld_b));
      if control_con = '0' then
        alu(zzero,nneg,ccy,alu_out,A,B,alu_op);
        zero <= zzero;
        neg <= nneg;
        cy <= ccy;
      end if;
    the value of "neg" alway is "U"
    Thank you very much
    You've set nneg as the output of the procedure, but it's no set to anything inside the procedure, so it will always return 'U'. nneg outside the procedure is completly separate from the nneg inside "alu", so the fact you initialised it doesnt matter, it will always be 'U'.
    To solve it, either remove nneg as an output from alu, or dont connect the external nneg to alu.
