I have once more question:
I program this code and I've already initial all value but the output zzero, ccy, sometime their value are "U", "1", "0". Their value are "1" and "0" it's Ok but the value is "U", I can not soft it. Could you help me?
VARIABLE A,B,C :std_logic_vector(15 DOWNTO 0):=(others => '0');
VARIABLE alu_out :std_logic_vector(15 DOWNTO 0):=(others => '0');
VARIABLE zzero,nneg,ccy :STD_LOGIC:='0';
constant z :std_logic_vector(15 downto 0) := (others => '0');
procedure alu (zzero,nneg,ccy :out STD_LOGIC;
alu_out :out std_logic_vector(15 DOWNTO 0);
a,b :in std_logic_vector(15 DOWNTO 0):=(others => '0');
alu_op :in UNSIGNED(2 DOWNTO 0):=(others =>'0')) is
variable alu_out_reg :std_logic_vector(16 DOWNTO 0):=(others => '0');
variable alu_out_or :std_logic_vector(31 downto 0):=(others => '0');
begin
case alu_op is
when "000" => alu_out_reg := ("0" & a) + ("0" & b); ------add
alu_out := alu_out_reg(15 downto 0);
ccy := alu_out_reg(16);
if alu_out_reg(15 downto 0) = z then
zzero := '1';
else zzero:= '0';
end if;
when others => null;
end case;
end alu;
BEGIN
A := RF(conv_integer(fld_a));
B := RF(conv_integer(fld_b));
if control_con = '0' then
alu(zzero,nneg,ccy,alu_out,A,B,alu_op);
zero <= zzero;
neg <= nneg;
cy <= ccy;
end if;
the value of "neg" alway is "U"
Thank you very much
