15 years ago --- Quote Start --- they are indeed the same --- Quote End --- It's apparently different with Terasic, i'll check occasionly. I guess, they did it because Quartus requests a driver installation every time a device with a new ID is plugged for the first time. So you have to edit the IDs with the FTDI tool if you want to connect more than one simultaneously.
