11 years agoTrying to get State Machine to Stop Glitching
Currently I am developing a sequencer that every 16 clock ticks one of the tx enables are high while the rx enables are kept high all the time. My state machine is working occasionally although I hav...
11 years agoI began to rewrite the code to get rid of some of the unnecessary factors mentioned above and developed this code bellow. Even after doing all that my code still glitches.
https://www.alteraforum.com/forum/attachment.php?attachmentid=11099 library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_textio.all; use IEEE.std_logic_unsigned.all; library STD; use STD.textio; ENTITY state_machine IS generic(txNum:integer:=5); PORT( clk : IN STD_LOGIC; reset : IN STD_LOGIC; txen_1 : out std_logic; txen_2 : out std_logic; txen_3 : out std_logic; txen_4 : out std_logic; txen_5 : out std_logic; rxen_1 : out std_logic; rxen_2 : out std_logic; rxen_3 : out std_logic; rxen_4 : out std_logic; rxen_5 : out std_logic); END state_machine; ARCHITECTURE a OF state_machine IS constant s0:STD_LOGIC_vector(2 downto 0):="000"; constant s1:STD_LOGIC_vector(2 downto 0):="001"; constant s2:STD_LOGIC_vector(2 downto 0):="010"; constant s3:STD_LOGIC_vector(2 downto 0):="011"; constant s4:STD_LOGIC_vector(2 downto 0):="100"; constant s5:STD_LOGIC_vector(2 downto 0):="101"; signal state: STD_LOGIC_vector(2 downto 0):=s0; signal cnt:STD_LOGIC_VECTOR(3 DOWNTO 0):="0000"; BEGIN process(clk) begin if(rising_edge(clk))then cnt<=cnt+1; end if; end process; PROCESS (clk,reset) BEGIN IF reset = '1' THEN state <= s0; ELSIF (rising_edge(clk)) THEN CASE state IS WHEN s0=> state <= s1; WHEN s1=> if(cnt="1111")then if(txNum=1)then state <= s1; else state <= s2; end if; else state <= s1; end if; WHEN s2=> if(cnt="1111")then if(txNum=2)then state <= s1; else state <= s3; end if; else state <= s2; end if; WHEN s3=> if(cnt="1111")then if(txNum=3)then state <= s1; else state <= s4; end if; else state <= s3; end if; WHEN s4=> if(cnt="1111")then if(txNum=4)then state <= s1; else state <= s5; end if; else state <= s4; end if; WHEN s5=> if(cnt="1111")then state <= s1; end if; when others=> state<=s1; END CASE; END IF; END PROCESS; PROCESS (state) BEGIN rxen_1<='1'; rxen_2<='1'; rxen_3<='1'; rxen_4<='1'; rxen_5<='1'; CASE state IS WHEN s0 => txen_1<='0'; txen_2<='0'; txen_3<='0'; txen_4<='0'; txen_5<='0'; WHEN s1 => txen_1<='1'; txen_2<='0'; txen_3<='0'; txen_4<='0'; txen_5<='0'; WHEN s2 => txen_1<='0'; txen_2<='1'; txen_3<='0'; txen_4<='0'; txen_5<='0'; when s3=> txen_1<='0'; txen_2<='0'; txen_3<='1'; txen_4<='0'; txen_5<='0'; when s4=> txen_1<='0'; txen_2<='0'; txen_3<='0'; txen_4<='1'; txen_5<='0'; when s5=> txen_1<='0'; txen_2<='0'; txen_3<='0'; txen_4<='0'; txen_5<='1'; when others=> txen_1<='1'; txen_2<='0'; txen_3<='0'; txen_4<='0'; txen_5<='0'; END CASE; END PROCESS; END a;
