11 years agoTrying to get State Machine to Stop Glitching
Currently I am developing a sequencer that every 16 clock ticks one of the tx enables are high while the rx enables are kept high all the time. My state machine is working occasionally although I hav...
11 years agoI'm not sure what's causing the problem, but you have a bug in your counter code:
SIGNAL cnt : INTEGER RANGE 0 TO 16 := 0;
PROCESS (clkrx)
BEGIN
IF (rising_edge(clkrx)) THEN
IF (cnt = 0) THEN
current_s <= next_s;
cnt <= cnt + 1;
p <= true;
ELSIF (cnt = 16) THEN
cnt <= cnt + 2;
ELSE
cnt <= cnt + 1;
END IF;
END IF;
END PROCESS;
You are defining a range from 0 to 16, but when you reach 16 you still increase the counter, getting out of range. This kind of behaviour is undefined in VHDL (and will cause an error in a simulator). I'm not sure what Quartus synthesizes in this case, but it's quite possible that it's an +1 adder that works fine with numbers from 0 to 16 and gives strange results for other values. Try this instead: SIGNAL cnt : INTEGER RANGE 0 TO 15 := 0;
PROCESS (clkrx)
BEGIN
IF (cnt = 0) THEN
cnt <= cnt + 1;
p <= true;
ELSIF (cnt = 15) THEN
cnt <= 0;
ELSE
cnt <= cnt + 1;
END IF;
END IF;
END PROCESS;It will synthesize as a regular adder, and uses one bit less. Which clock frequency are you using for this design? Did you constrain your project for Timequest?
