17 years agoTrouble with state-machine
I'm trying to build a state-machine in AHDL using Quartus 2 v7.2. During compilation I get these messages: Warning (14130): Reduced register "..." with stuck clock port to stuck value GND Warning (14110): No clock transition on "..." register due to stuck clock or clock enable Later in compilation, I get this message, telling me that the output of the state-machine is at ground: Info: Pin AT has GND driving its datain port Here is a state-machine like I programmed, I must have made some terrible mistakes. Can tell whose? SUBDESIGN state_machine2 ( s[2..0] : INPUT; Takt0 : INPUT; %clock% AT : OUTPUT; ) VARIABLE AT : dff; M1 : MACHINE WITH STATES (zero, one, two); BEGIN AT.clk = Takt0; M1.clk = Takt0; CASE M1 IS WHEN zero => AT = B"0"; IF (s[] == 1) THEN M1 = one; ELSIF (s[] == 2) THEN M1 = two; ELSE M1 = zero; END IF; WHEN one => AT = B"1"; IF (s[]==1) THEN M1 = one; ELSIF (s[]==2) THEN M1 = two; ELSE M1 = zero; END IF; WHEN two => AT = B"0"; IF (s[]==1) THEN M1 = one; ELSIF (s[]==2) THEN M1 = two; ELSE M1 = zero; END IF; WHEN others => M1 = zero; END CASE; END;
