13 years ago
Trouble with EPCS pin assignments in Quartus II 11.0
I am using an EPCS16 to configure a Cyclone III EP3C25Q240 and configuration works fine.
However, I also want to use the EPCS16 for Remote Update, which requires that I connect the EPCS signals to the epcs_controller component of my Qsys design in Quartus II. When I do this I get the following error message from the QII compiler:
error: cannot place i/o pin epcs_data with i/o standard 3.3-v lvcmos in pin location 24 -- possible switch coupling with i/o pin epcs_dclk in pin location 23.
This is nonsense of course since the pins I am using are the correct ones for the EP3C25Q240, and the serial configuration works.
How can I convince Quartus II to allow this pin configuration without generating an error?
    I remember previous "nonsense" errors related to EPCS pins. I guess, in this case assigning 0 MHz toggle rate to the DCLK pin in pin planner or assignment editor will help.
    That did the trick, my design now compiles and I can program the EPCS through JTAG. I haven't tried it with Remote Update yet, but hopefully that will work too.
    Thanks FvM for the quick reply. Saved me countless hours. :)
