16 years ago
Trouble to run NIOSS II processor...
I had some trouble to run the NIOS II processor without chaniging anything (You can see my previous post here http://www.alteraforum.com/forum/showthread.php?t=6003 )!
Because I don't find any way to solve my problem I decided to close all apps, restart the computer and to make a very new Quartus II project (in a new directory..)
In SOPC I add only three component :
- The NIOS II processor
- An onchip_mem
- A Jtag_uart
In the Block diagram file I add only two input pins, thelock and the reset (which is negative logic, of course..)
I have a good compilation in Quartus II and when I program the FPGA, I get the OpenCore Status window which is connect without any problem !
Then I launched a new NIOS II project (with a new workspace....)
I made a hello_world_small project..
The compilation was successful but I get this message in the output console !
Using cable "USB-Blaster ", device 1, instance 0x00
Pausing target processor: not responding.
Resetting and trying again: FAILED
Leaving target processor paused
I don't understand why I have this problem without changing anything !!
Please help me !
Thank you..
1 Reply
    @themanman
    Did you assign your "clk" and "reset_n" signals to the PIN's of your FPGA?
