12 years ago
Trouble setting signal value <advanced>
I have made this program as part of an assignment where I'm supposed to design a one bit voter, for micro controllers use in a student satellite. The code works except the part where i am trying to reset the circuit.
In the sync process i have a signal, clear_input_ok, if this is set to '1' by the reset, the input_ok is supposed to be set to "1111" in the combinatorial process. This doesn't work though, I've asked my TA, and my professor, and they haven't fount a solution, and say that it should work. I will include source code. Thanks in advance!
library IEEE;
use IEEE.STD_LOGIC_1164.all;
entity Voter is
    port(
        CLK : in STD_LOGIC;
        a : in STD_LOGIC;
        b : in STD_LOGIC;
        c : in STD_LOGIC;
        d : in STD_LOGIC;
        reset : in STD_LOGIC;
        y : out STD_LOGIC;
        status : out STD_LOGIC_VECTOR(2 downto 0)
end Voter;
--}} End of automatically maintained section
architecture Voter of Voter is
    SIGNAL input_ok: STD_LOGIC_VECTOR(3 downto 0);
    SIGNAL clear_input_ok: STD_LOGIC;
    SIGNAL async_status: STD_LOGIC_VECTOR(2 downto 0);
    SIGNAL result_y: STD_LOGIC;
begin
    sync:
        process (CLK,reset)
    begin
        if reset = '1' then
            clear_input_ok <= '1';
        else clear_input_ok <= '0';
        end if;
        if clk = '1' then
            status <= "000";
            y <= result_y;
            status <= async_status;
        end if;
    end process sync;
    comb:
        process  (a,b,c,d, clear_input_ok)
        VARIABLE vote_one : INTEGER RANGE    0 TO 4;
        VARIABLE vote_null : INTEGER RANGE    0 TO 4;
        VARIABLE failed : INTEGER RANGE 0 TO 4;
        VARIABLE result : STD_LOGIC;
    begin
        failed := 0;
        vote_one := 0;
        vote_null := 0;
        async_status <= "000";
        if (clear_input_ok = '1') THEN
            report("if statement runs!");
            input_ok <= "1111";
            end if;
        ------- inkrements voting variables----------
        if (input_ok(0) = '1') THEN
            if (a='1') THEN
                vote_one:= vote_one +1;
            else vote_null:= vote_null +1;
            end if;
        else
            vote_one := vote_one +1;
            vote_null := vote_null +1;
        end if;
        if (input_ok(1) = '1') THEN
            if (b='1') THEN
            end if;
        else
        end if;
        if (input_ok(2) = '1') THEN
            if (c='1') THEN
            end if;
        else
        end if;
        if (input_ok(3) = '1') THEN
            if (d='1') THEN
            end if;
        else
        end if;
        ----- figure out result ------
        if (vote_one = 4) THEN
            result := '1';
        end if;
        if (vote_null = 4) THEN
            result := '0';
        end if;
        -----check if there is contradicting values, and how many? and uppdate failed----------
        if (a /= result) OR input_ok(0) = '0' THEN
            input_ok(0) <= '0';
            failed := failed +1;
        end if;
        if (b /= result) OR input_ok(1) = '0' THEN
            input_ok(1) <= '0';
        end if;
        if (c /= result) OR input_ok(2) = '0' THEN
            input_ok(2) <= '0';
        end if;
        if (d /= result) OR input_ok(3) = '0' THEN
            input_ok(3) <= '0';
        end if;
        ----- uppdate status------
        if failed = 0 THEN
        end if;
        if failed = 1 THEN
            async_status <= "001";
        end if;
        if failed = 2 THEN
            async_status <= "010";
        end if;
        if failed > 2 THEN
            async_status <= "111";
        end if;
        ------uppdate result-------
        result_y <= result;
    end process comb;
end Voter;
    --- Quote Start ---
    library IEEE;
    entity Voter is
        port(
            CLK : in STD_LOGIC;
            a : in STD_LOGIC;
            b : in STD_LOGIC;
            c : in STD_LOGIC;
            d : in STD_LOGIC;
            y : out STD_LOGIC;
    end Voter;
    begin
        sync:
            process (CLK,reset)
        begin
            if reset = '1' then
            end if;
            if clk = '1' then
                status <= "000";
                y <= result_y;
            end if;
        end process sync;
        comb:
        begin
            failed := 0;
            vote_one := 0;
            vote_null := 0;
                input_ok <= "1111";
                end if;
                if (a='1') THEN
                end if;
            else
            end if;
                if (b='1') THEN
                end if;
            else
            end if;
                if (c='1') THEN
                end if;
            else
            end if;
                if (d='1') THEN
                end if;
            else
            end if;
                result := '1';
            end if;
                result := '0';
            end if;
                input_ok(0) <= '0';
            end if;
                input_ok(1) <= '0';
            end if;
                input_ok(2) <= '0';
            end if;
                input_ok(3) <= '0';
            end if;
            if failed = 0 THEN
            end if;
            if failed = 1 THEN
            end if;
            if failed = 2 THEN
            end if;
            if failed > 2 THEN
            end if;
            result_y <= result;
        end process comb;
    end Voter;
    --- Quote End ---
    you must be updating input_ok back to zeros on last statements in the comb process. Remember it is sequential process and last statements overwrite.
