Altera_ForumHonored Contributor12 years agoTrouble setting signal value <advanced> I have made this program as part of an assignment where I'm supposed to design a one bit voter, for micro controllers use in a student satellite. The code works except the part where i am trying to r...Show More
Altera_ForumHonored Contributor12 years agoThank you for reply. I will take your advice and start over again.
Recent DiscussionsTiming analysis - long combinational pathAutomatically added negative node for TDS output doesn't work with Agilex 5Quartus 20.1std compilation fails for Quartus map - Device 10AS057K2F40I1SGDuplicate_hierarchy_depth / duplicate_registerQuartusPro 25.3 Crashed after using the Signal Tap Logic Analyzer
