It's not clear to me, if the reported observations are only misinterpretation of simulation results or also in part indicating bad HDL coding. Somes lines of code should clarify this.
Regarding the counter issue:
--- Quote Start ---
- some values are in the wrong order (3,2,5,4,7,6,9,8 instead of 1,2,3,4,5,6,7,8,9)
--- Quote End ---
It may be the case, that you are reading an internal counter value, that is using a different internal coding due to optimizations. You should feed the counter to an external port to see the real counter value. If the counter is actually counting wrong, bad coding must be expected.
