CFabr1
6 years agoTranslating to Verilog and compiling Maxplus2 .bdf examples
Hi all, I'm trying to translate to Verilog some Maxplus2 examples (in .bdf format) of TTL gates but I get some errors when compiling.I'm using Quartus 12.1 For example, this is the generated Verilo...
ak6dn
6 years agoOk, maybe I was not being clear enough. ANYWHERE a non-standard format identifier (ie, starting with an alphabetic, and then containing only alphabetic, numeric, or underscore) is used it MUST be escaped. So in your above code, the identifiers in the module port list, in the assign statements, and those in equations in the always blocks need escaping. Here is what your code should look like:
module \7474 (
\2CLRN ,
\2CLK ,
\2D ,
\2PRN ,
\1CLRN ,
\1CLK ,
\1D ,
\1PRN ,
\1Q ,
\1QN ,
\2Q ,
\2QN
input wire \2CLRN ;
input wire \2CLK ;
input wire \2D ;
input wire \2PRN ;
input wire \1CLRN ;
input wire \1CLK ;
input wire \1D ;
input wire \1PRN ;
output wire \1Q ;
output wire \1QN ;
output wire \2Q ;
output wire \2QN ;
reg DFF_10;
reg DFF_9;
assign \1Q = DFF_9;
assign \2Q = DFF_10;
always @(posedge \2CLK or negedge \2CLRN or negedge \2PRN )
begin
if (!\2CLRN )
begin
DFF_10 <= 0;
end
else
if (!\2PRN )
begin
DFF_10 <= 1;
end
else
begin
DFF_10 <= \2D ;
end
end
assign \2QN = ~DFF_10;
assign \1QN = ~DFF_9;
always@(posedge \1CLK or negedge \1CLRN or negedge \1PRN )
begin
if (!\1CLRN )
begin
DFF_9 <= 0;
end
else
if (!\1PRN )
begin
DFF_9 <= 1;
end
else
begin
DFF_9 <= \1D ;
end
end
endmodule
