11 years agoHi, I tried to find the correct argument from the pdf file you gave, and I tried 0, 1, ...
However, error message still shows up as before. Do I have to add additional mark at the register value? For reference about the command, additional information from "Debugging Transceiver Links" is as follow. "Sets the output pattern specified by the <pattern-name>. In all, 6 patterns are available, 4 are pseudo-random binary sequences (PRBS), 1 is high frequency and 1 is low frequency. The PRBS7, PRBS15, PRBS23, PRBS31, HF (outputs high frequency, constant pattern of alternating 0s and 1s), and LF (outputs low frequency, constant pattern of 10b’1111100000 for 10- bit symbols and 8b’11110000 for 8-bit symbols) pattern names are defined. PRBS files are clear text and you can modify the PRBS files" Thanks.
