11 years ago --- Quote Start --- Succeed.Thanks. --- Quote End --- Great! --- Quote Start --- But I have another question. I want to set the data pattern through using "transceiver_debug_link_set_pattern" command. As an argument of the command, there is <data pattern>. I wrote PRBS7 as the argument. However, there is an error that indicates as "The specified pattern, PRBS7, is not valid." Is there any form to write this argument? --- Quote End --- Perhaps its the pattern register setting, eg., 1, 2, 4, 8, 16, 32. The data pattern generator component registers used to be in the "Embedded Peripheral IP Users Guide", but Altera have moved them ... perhaps into the Quartus handbook ... I've uploaded chapter 36. Try using the pattern type register values. Cheers, Dave
