14 years agoHi, i'm the colleague of thomas and i wrote the firmeware.
Here are some additional information about the transceiver configuration.- Protocol: Basic X4
- Transmitter only
- Effective datarate : 1720 Mbps
- inclk frequency : 430 MHz
- PLL bandwith: Auto
- VCCHTX: Auto
- Pre-emphasis pre-tap: 0
- Pre-emphasis first Post-tap: 0
- Pre-emphasis second post-tap: 0
- Self test mode: none
- low latency PCS mode is enabled
- No reconfiguration and loopbacks
u_tx_channel : tx_channel
port map
-- inputs
cal_blk_clk => i_tx_calibration_clk,
cal_blk_powerdown => '0',
pll_inclk => i_tx_ref_clk,
pll_powerdown => '0',
tx_digitalreset => '0',
tx_datain => x"AAAAAAAAAAAAAAAA",
coreclkout(0) => memory_clk,
tx_clkout => open,
tx_dataout => tx_dataout_sig
Now I try to connect to the transceiver via the transceiver toolkit. I load the design and clicked on "Link Instance to device ...." but nothing happened. No Transmitter Channel is displayed.
