14 years ago
Transceiver Pin Assignment for Stratix 4 GX
Hi
i implemented a transceiver with the ALTGX megafunction and want to assign the pins (tx_dataout_sig[1...4]).
The I/O Standard should be 1.4V PCML. (As seen in the assignments)
set_location_assignment IOBANK_QL1 -to tx_dataout_sig -disable
set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to tx_dataout_sig -disable
set_location_assignment PIN_AD36 -to tx_dataout_sig
set_location_assignment PIN_AD37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_AB36 -to tx_dataout_sig
set_location_assignment PIN_AB37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_T36 -to tx_dataout_sig
set_location_assignment PIN_T37 -to "tx_dataout_sig(n)"
set_location_assignment PIN_P36 -to tx_dataout_sig
set_location_assignment PIN_P37 -to "tx_dataout_sig(n)"
set_instance_assignment -name BOARD_MODEL_TERMINATION_V "HALF VCCIO" -to tx_dataout_sig
set_instance_assignment -name IO_STANDARD "1.4-V PCML" -to "tx_dataout_sig(n)"
set_instance_assignment -name CKN_CK_PAIR ON -from tx_dataout_sig -to "tx_dataout_sig(n)"
But the signal displayed on my scope is only from 84mV to 212mV... So it's nothing about 1.4V PCML.
Do I have to set any other settings?
Thanks for your help!
Thomas
1 Reply
    Hi, i'm the colleague of thomas and i wrote the firmeware.
    Here are some additional information about the transceiver configuration.
    • Protocol: Basic X4
    • Transmitter only
    • Effective datarate : 1720 Mbps
    • inclk frequency : 430 MHz
    • PLL bandwith: Auto
    • VCCHTX: Auto
    • Pre-emphasis pre-tap: 0
    • Pre-emphasis first Post-tap: 0
    • Pre-emphasis second post-tap: 0
    • Self test mode: none
    • low latency PCS mode is enabled
    • No reconfiguration and loopbacks
    We use the Stratix IV signal integrity development board DK-SI-4SGX230N.
    I only want to put out a pulscode of '1010...'. The calibration clock signal is the 100 MHz clock from the development board (PIN_A34, LVDS).
    i_tx_ref_clk is connected to the transceiver clock PIN_AN38 (LVDS) and generated by a Rohde&Schwarz SMHU Signal Generator ( 430MHz, sine wave)
        u_tx_channel : tx_channel
          port map
            -- inputs
            cal_blk_clk            => i_tx_calibration_clk,
            cal_blk_powerdown => '0',
            pll_inclk                 => i_tx_ref_clk,
            pll_powerdown        => '0',
            tx_digitalreset        => '0',
            tx_datain               => x"AAAAAAAAAAAAAAAA",
            coreclkout(0)         => memory_clk,
            tx_clkout               => open,
            tx_dataout             => tx_dataout_sig
    Now I try to connect to the transceiver via the transceiver toolkit. I load the design and clicked on "Link Instance to device ...." but nothing happened. No Transmitter Channel is displayed.
