13 years ago --- Quote Start --- okay.. if the coding like this library ieee; use ieee.std_logic_1164.all; entity peak_mode is port (clk: in bit; RT1, RT2,RT3, RT4, RT5, RT6, GT1, GT2, GT3, GT4, GT5, GT6, YT1, YT2, YT3, YT4, YT5, YT6: out bit); end peak_mode; i want to know, how can i assign pin for the output?means on the traffic light board.i also not understand how GPIO pin function. --- Quote End --- You can use pin planner in Quartus II to assign the inputs and outputs of your top entity code.
