15 years agoI made a test for both '0' and '1' at the same time. I had this virtual pin drive a led-blinker, when '0' we have a 2Hz blink, when high a 10 Hz.
When I connected the initialised to '1' virtual pin, the led flashed a 2Hz, steadily. I then connected the initialised to '0' virtual pin, but inserted an inverter along the way, the led flashed at 10Hz, again steadily. So I think I am safe to conclude that a virtual in pin of a top level module, the module that ultimately connects the pins, carries a '0' value. If you look in the Technology Map Viewer in Post-Fitting mode you can find the LUT you mention, but it has a '0' feeding out ...
