15 years ago --- Quote Start --- I think this would still cause a problem in the target hardware if a virtual pin results in a floating input as you cannot guarantee the input level, thus this would be sampled and ripple through reg1->reg2-> to the simulation control signal. Can someone confirm that a virtual pin results in a disconnected signal i.e. left floating in the target FPGA? --- Quote End --- It will not propagate due to the latching. Once pin is zero (of floating states) it will be latched by reg2 and reg2 will no longer see the pin
