15 years agoThanks josyb.
I understand what a virtual pin is for but what I would like to determine is what QuartusII internally assigns the virtual pin node too. The help says it uses a LUT for a virtual pin so does this mean it is assigned VCC, GND or left floating? Is the LUT value deterministic? Your test results are interesting as it suggests it is assigned to GND but I don't think we could conclude that because a floating node can still produce this outcome. I am not sure where to go with this one.
