15 years agoYou could define a generic parameter in the entity like:
SIMULATION : std_logic := '1' ; -- chose '0' or '1' and use the SIMULATION parameter to other logic like a normal signal.
process( ... , SIMULATION , ... )
begin
if (SIMULATION = '1') then
counter <= SMALL ;
else
counter <= LARGE ;
end if ;
Beware the compiler now has a 'fixed' value and will possibly optimize registers away, but the design will operate correctly. If you want to retain the netlist with a selectable simulation signal, but don't want to use a pin for it, you have to find a way to set an internal register by using a few input signals in a combination that 'never' exists in nirmal operation. Another idea might be to use the Data0 signal, in Passive Serial configuration (and possibly other modes too, but I never use those, so I don't know) you can declare Data0 to be used for logic after configuration, make it an input and keep it high or low.
