12 years agoHere is the user guide for the floating point IP cores. Its updated for the latest version (13.1) but I dont think the float ip cores have really changed in that time. http://www.altera.co.uk/literature/ug/ug_altfp_mfug.pdf
The latest version of the free web edition is available from here: http://www.altera.co.uk/products/software/quartus-ii/web-edition/qts-we-index.html As for frequency - its really down to your application. If you need to run at 100 MHz you will struggle to get anywhere near that with the floating point library (you may be stuck at <20MHz). With the float IP cores, with enough pipelining, >200MHz should be achieveable.
