12 years agoI worked around this problem by converting the integer to unsigned. To convert integer to unsigned or signed data type over,
use IEEE.NUMERIC_STD.all;you must use, to_unsigned(I,U’length);to_signed(I,S’length)where I is the integer value and U'length is the unsigned vector length ( the number of bit ). The to_float(unsigned) function doesn't cause any problems.
